extreme noob question
Discussion in 'General Electronics Discussion' started by DavidtheGreat, Apr 29, 2014.
  1. DavidtheGreat
    DavidtheGreat
    3
    Apr 29, 2014
    Hello everyone, I'm just getting into doing some electric hobby stuff. I'm building a hardwired overdrive pedal for my guitar. So far, the only problem I've run into is that I can't find a 2Mohm resistor anywhere. Is it possible to use 2-1Mohm resistors in it's place? If so, how do configure them if they're going into the same position on the terminal strip? I've heard that if you wind them together in parallel, they'll cancel half of their value, so I'm kind of lost as to what to do. Does anyone mind explaining this to me in idiot terms. Thanks, David
  2. kpatz
    kpatz
    329
    88
    Feb 24, 2014
    Wire two 1M resistors in series. In other words, connect the two resistors end-to-end, then connect the two remaining (unconnected) ends into the circuit in place of the 2M resistor.
    So, instead of -----2M----- you'd have -----1M----1M----
    KrisBlueNZ likes this.
  3. DavidtheGreat
    DavidtheGreat
    3
    Apr 29, 2014
    Wow, that was easy. I thought it would be a lot harder than that...Thanks so much for your help Kpatz.
  4. KJ6EAD
    KJ6EAD
    1,114
    159
    Aug 13, 2011
  5. DavidtheGreat
    DavidtheGreat
    3
    Apr 29, 2014
    Wow, thanks KJ6EAD
