D
DaveC
Where did you get this heatsink? I'd like to get one to add to my U800.
Surplus electronics shop here in Sillycon Valley.
I spoke with a Tek engineer who told me that excessive heat was the
failure mode for U800 and that heatsinking it is a good idea, so I think
you're on the right track.
Intuitively, it just seemed like the right decision.
I know someone else who heatsinked his U800 and hasn't had any problems
so far. The only caveat he said is the studs are at -5V so one has to be
sure that the heatsink doesn't touch the case...
There are little vinyl "nipples" that slip over the studs to insulate them.
Just be sure to put them back on when you've finished the job. Might be
prudent to trim those nipples to accomodate the additional height of the nuts
and heat sink. Not much, just a few mm.
There is a flat cable connector that plugs onto header J102; you can see the
header pins in this photo:
http://home.covad.net/~peninsula/Before.jpg
It's easy to pull the connector off. I didn't notice, and got Counter/Timer
option errors on startup. (If you don't have C/T option, might not have this
connector; don't know...). Also was told that it is common to pull off one of
the coax cables running through this area, which gives similar power-on
diagnostics errors.
This heat sink fits nicely over the J102 connector when properly installed.
Was like it was made for this application
Don't overtighten the nuts. You could stress the studs and possibly pull them
from the PCB, which means they might come out and bounce around the circuit
area (!). Not a good thing...
Good luck,
