S
sno
It seems to me that the real problem is your inability to bury the line
leading from the pressure tank to your house deep enough to prevent it
from freezing.
I'm wondering if you might be able to run that water line through a
larger black plastic pipe through which you feed just enough warm air to
prevent the water in the inner pipe from freezing...
If that's possible, then you not only solve the frozen pipe problem, but
you also solve the problem with the relay and you probably extend the
life of the pump at the same time...
Hmmmmm....interesting thought...could blow the hot air off a lite bulb
with a computer fan from the pump house, if snubber doesn't works then
maybe can rig something up like that..should have the components for
snubber next week...got my fingers crossed, as that is the least
expensive/easiest to do..not worried about pump as has lasted well over
10 yrs., will see...thanks for the thought.....have fun.....sno
