Extend the life the TV lamp
Does anyone know why the lamp goes out? My TV's lamp failed after 2
1/2 years. I disassembled the lamp all the way to the wires to figure
out what is wrong with it. I have concluded that the lamp is filled
with inert gas and sealed with a cheap white compound, after this
white compound is exposed to heat over many hours; it will
disintegrate, cracks, and let the gas to escape leading to lamp to
fail. Solution: SONY should seal the lamp using glass type seal that
is used on the old type household light bulb. The lamp life should be
extended to >50,000 hr.
W
William Sommerwerck
I assume this is a joke. Lamps go out because the filament eventually burns
through.
E
Eeyore
through.
I imagine he meant a cold cathode type backlight for illuminating LCDs.
Graham
James Sweet
through.
There won't be an incandescent lamp in a TV.
Cold cathode fluorescent lamps fail because the cathodes wear out, usually
the phosphor is depreciated by then as well.
UHP lamps in DLP and LCD sets fail because the quartz arc tube devitrifies,
they run about 3,000 PSI in operation and will fail catastrophically if run
too far past rated life.
G
Gary Tait
[email protected] wrote in 22g2000hsm.googlegroups.com:
The white compound does not seal the contents of the bulb inside it. It
just adheres it to the reflector and other works.
A
Adrian C
Troll
posting-account=ps2QrAMAAAA6_jCuRt2JEIpn5Otqf_w0
A
Art
Certianly hope you did not mind handling the mercury (HG) during that
procedure, BTW did you do in on the kitchen table also?
James Sweet
There's very little mercury in one of those lamps. I wouldn't sprinkle it in
my food, but there's no need for the paranoia about it either. An old
thermometer contains hundreds of times the mercury.
E
Eeyore
Our silly excessively risk-averse society has demonised such things without
adequate reason.
Now, if you were mining the stuff, that was different.
http://en.wikipedia.org/wiki/Almadén
Graham
S
Sam Goldwasser
There's such paranoia about mercury when so many common chemicals are
much more hazardous.....
I used to play with mercury as a kid and look what happened... I turned
into an engineer. Ooops. :)
--- sam | Sci.Electronics.Repair FAQ: http://www.repairfaq.org/
| Mirror Sites: http://www.repairfaq.org/REPAIR/F_mirror.html
ignored unless my full name AND either lasers or electronics is included in the
subject line. Or, you can contact me via the Feedback Form in the FAQs.
M
Meat Plow
Small amounts of mercury can be biologically manipulated into much more
hazardous forms like methyl mercury. This has happened several times in
history resulting in the poisoning of thousands of people.
Jerry Peters
adequate reason.
I believe that a large part of the problem is that the current crop of
journalists are almost totally ignorant of science and technology,
even perhaps to the point of being afraid of them. Add all sorts of
advocacy groups that invent their own "science" in support of their
causes and you get our current situation.
Jerry
E
Eeyore
In addition to ignorance you can add 'can't be bothered to research' to the list of
skills held by journalists today. They'll happily reprint any old nonsense they're
spoon fed.
Graham
M
Michael A. Terrell
You KNOW that you're not supposed to admit that online, Sam! ;-)
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
