That makes good sense. Somewhere in this thread, I thought
you were holding these transformers up as something state of
the art, close to the ultimate, not just very functional and
better than most. Fair enough.
The O.P. seemed interested in finding transformers that
perform well at frequencies (possibly much) higher than 25
kHz, not just in the audio spectrum. Are you proposing he
use these? I was just thinking about where the first
limitations for say, (pulling a number out of my ass) 100
kHz use would occur with your design.- Hide quoted text -
- Show quoted text -
Those transformers are designed to be much better than those commonly
used for PA distribution without being priced radically higher, and
they are. For crazy Phil's benefit, I dragged one out and measured its
magnatizing inductance: 7.8 Henry at 1 kHz. Leakage inductance, as
measured on the secondary side for the 70.7V (100 watt) tap, was 13
microHenry. That's really pretty good, if I do say so myself. These
are also not autotransformers, which makes the job of reducing leakage
inductance more difficult. However, any transformer designed to
transfer power is a compromise, so choose the best compromise for your
app. Returning to the OP's quest for extended HF response, there have
been several good suggestions. If he sticks with a single transformer,
crazy Phil is absolutely right to say that leakage inductance is the
main limiting factor, but it results in a simple rolloff for at least
an octave or 2, and core saturation is not a problem at high
frequencies, so some sort of pre-emphasis can be used to compensate.
Paul Mathews
