G
[email protected]
I recently purchased a Swann D-CAM which is just a cheap plastic case
in the shape of a security camera with a relatively small CMOS sensor
module sitting at the front. I put the module into a smaller case and
installed it facing out of my front window.
Next day it was obvious that the sunlight was a little too much for
the sensor, it is clearly overexposing (although not horribly). I'm
thinking of sacrificing some night-time sensitivity and SNR by either
placing a filter over the lens, or perhaps some window tint on a small
section of the window glass.
The specs say the shutter range is between 1/60 and 1/15000. Is this
typical for a CMOS module? Would a CCD module fare better in this
regard?
This is just an experiment at the moment, the D-CAM cost all of $29 as
Tricky Dicky are clearing them out. In the long run it would probably
be better to use something with an electro-mechanical iris and the
ability for my computer to control exposure based on the portion of
the frame it wants to expose for (ie, if it's sunny then blow out the
background, I want to see the person's face, not detail of my concrete
driveway!)
Any tips appreciated... my front door was forced by an unknown
intruder while I was standing right behind it.
regard?
driveway!)
