A
Ardent
X-No-Archive: yes
Hi all
I have been trying to play with driving a motor with PWM using
different circuits off the web, using 555, OpAmps.However I could not
get satisfactory results with a motor that needed 6 amps at12 volts..
I finally made a good PWM system using a microcontroller and just 38
bytes of code.
The part I want to tell about is the control of the motor.I used a
decade switch which gave me no rotation at 0 setting and then 9
speeds, at 9 at the decade switch I got 90% speed. This has made the
whole thing very simple
Hope this helps someone.
Hi all
bytes of code.
