I bought something like this off Ebay:
http://g02.a.alicdn.com/kf/HTB1S5xy...ont-2A-Pull-Type-Linear-font-b-Solenoid-b.jpg
Turns out it wasnt as powerfull as i need it to be but it has the right amount of travel and is nearly perfect in size...
Notice that the body where the coils are is fairly short. What if i made my own? But MUCH longer body, (theres plenty of room in my aplication LENGTH-wise) will it get more powerfull? Can i make it more powerfull by adding more coil?
Turns out i have plenty of coil like the one used in my solenoid, i have plastic pipe similar size and i can CNC the central "plunger" rather easy as well. Or make it different shape etc...
Im using a 11.1V lipo battery, something you can find in RC-cars. Increasing voltage/amps IS NOT AN OPTION.
So, in simplicity, if i make a solenoid like mine, but longer, can it pull greater load than the original or do i need to do something else as well?
