Experiment with NPN transistor BC547
Discussion in 'General Electronics Discussion' started by Djsarkar, Nov 1, 2020.
  1. Djsarkar
    Djsarkar
    46
    4
    Jul 27, 2020
    Hi
    I am trying to switch on LED using transistor. I have a one BC547 transistor, potentiometer 470 ohm resistor and LED.
    When I adjust pot LED doesn't turn ON What's wrong with connection?
  2. bertus
    bertus Moderator
    1,282
    503
    Nov 8, 2019
    Hello,
    Can you post a schematic, in stead of the breadboard?
    Schematics are the universal electronic language.
    Bertus
    Djsarkar likes this.
  3. Djsarkar
    Djsarkar
    46
    4
    Jul 27, 2020
    okay here is my schematics diagram
  4. bertus
    bertus Moderator
    1,282
    503
    Nov 8, 2019
    Hello,
    I hope you did not turn the potmeter fully to the +5 Volts.
    If you did so, the transistor might not have survived the action and got burned out.
    The base current may not exceed 20 mA.
    Bertus
  5. Djsarkar
    Djsarkar
    46
    4
    Jul 27, 2020
    Hi Bertus
    What's wrong in my connection ?
    How to verify transistor weather its okay or burnt ?
  6. bertus
    bertus Moderator
    1,282
    503
    Nov 8, 2019
  7. bertus
    bertus Moderator
    1,282
    503
    Nov 8, 2019
    Hello,
    If you want to make better looking schematics, you can copy paste symbols from this sheet into your schematic drawing:
    Your schematic could look like this:
    Bertus
  8. Djsarkar
    Djsarkar
    46
    4
    Jul 27, 2020
    Hi
    I have attached test result. Does led will damage if I set pot to full 5 volt?
  9. bertus
    bertus Moderator
    1,282
    503
    Nov 8, 2019
    Hello,
    No, the led is protected by the 470 Ohms current limiting resistor.
    The transistor can be dameged by a to large base current.
    When you put a resistor of 1K between the top of the potentiometer and the +5 Volts, the transistor is protected from a to high base current.
    Bertus
    Cannonball and Djsarkar like this.
  10. Djsarkar
    Djsarkar
    46
    4
    Jul 27, 2020
    Hi
    I want to perform experiment to see how the transistor work as switch. I have attached a circuit diagram
    Cannonball likes this.
  11. bertus
    bertus Moderator
    1,282
    503
    Nov 8, 2019
    Hello,
    That should work fine.
    The base current is limited by the 1K resistor.
    The led is protected by the 470 Ohms resistor.
    Bertus
  12. kpatz
    kpatz
    318
    84
    Feb 24, 2014
    Your "transistor as a switch" circuit should work fine. Try it out!
    One characteristic of transistors you should know about is that they have what's called "gain". Which means a small current flowing from base to emitter can control a much larger current from collector to emitter. The BC547 has approx 100-800x current gain, so you could use a much higher resistor on the base and the transistor will still turn on fully. For example, a 100K resistor would work, though 10K is more commonly used to ensure the transistor is fully "on" even if you're switching larger currents. For your little LED, a higher base resistor will work no problem.
    With your circuit using a pot, you can see how the transistor responds over its "linear region" as well. This is the region in between "fully off" and "fully on". When the B-E voltage reaches 0.55V or so the junction starts to conduct and the transistor starts to turn "on". At around 0.7V it will reach saturation and be fully "on". This is a narrow range near the bottom travel of your pot, where it transitions between fully off, partially on, and fully on.
    Since a transistor can control a much larger current using a smaller current, it works as an amplifier, like those in radios, cell phones, etc., and it can also be used to allow a small voltage/current to switch on/off a larger current.
  13. Cannonball
    Cannonball
    191
    53
    May 6, 2017
    You may instead do away with the pot and use a 10k resistor from collector to the switch and from the switch to the base. That should work as well.
  14. Harald Kapp
    10,770
    2,426
    This will work but will not be efficient: When the transistor turns "on", Vce will fall towards 0 V thus reducing Vbe (via Rcb from collector to base). As the transistor needs Vbe = 0.6 V ... 0.7 V to turn on, Vce cannot fall below this value.
    Better: Connect the resistor to V+ as shown by Bertus in post #9. Here the transistor can go into full saturation where Vce = 0.1 V (in the ballpark of), thus reducing power dissipation across the transistor and supplying 0.5 V ... 0.6 V more to the load.
    In the case of a simple LED as load this may not have a noticeable influence at all as the load is small. But if you were to drive a high load through e.g. a power transistor, every millivolt counts. At a load current of e.g. 1 A (! the BC547 will not be able to drive this current!), a difference of 0.5 V in Vce results in 0.5 W power dissipation that would have to be taken care of.
    This is one reason why Darlington transistors are not well suited to drive high current loads despite their high gain.
  15. ratstar
    ratstar
    308
    13
    Aug 20, 2018
    One more thing to add, if you dont put a resistor with the potentiometre, youll actually steal all the current from the collector as well, because itll short to the base.
    And it definitely seems like a situation where the transistor would be fried.
    But if the 2 5v entry points, where separate isolations, this current theivery actually doesnt happen, but u probably would have fried anyway.
  16. Harald Kapp
    10,770
    2,426
    Huh? Makes no sense at all, please explain.
  17. ratstar
    ratstar
    308
    13
    Aug 20, 2018
    if you have 2 isolated positives, (must go with) 2 isolated negatives. the current will add up on the lines, and they only short circuit within themselves.
    To get an isolated pos+neg, you need a capacitor, a battery, or a transformer.
    1 isolation, will only ever attract to itself, and 2 isolations can literally pass straight through each other (in a subtraction) and pop out the other sides full strength again.
    If youve never known that your whole life, it may be a bit of a shock to you...
  18. Harald Kapp
    10,770
    2,426
    I dare think I know a tad more about electronics than you do :rolleyes:
    ratstar likes this.
