Rusty_Shackleford
- Aug 18, 2021
- 11
- Joined
- Aug 18, 2021
- Messages
- 11
Hello, I'm looking for a suitable panel mounted barrel connector jack which I can use for a project I'm working on. I want something like this: Amazon.com: E-outstanding 5-Pack DC-099 5.5 mm x 2.5mm 30V 10A DC Power Jack Socket,Threaded Female Panel Mount Connector Adapter : Electronics. The issue is that I'm using a 20A power supply, and all of the connector jacks that I'm finding are rated for 10A or lower. My question is what would happen if I use a power input jack that is rated for only 10A, would this cause a failure of some sort if I exceed the current rating by a significant amount? This is the only point in the circuit where the current rating would be exceeded.
If using a jack such as this one is not a viable solution, does anyone know where I could find a similar component which can handle 20A?
