Example of good documentation
Discussion in 'Electronic Design' started by Boris Mohar, Mar 21, 2007.
  1. Boris Mohar
    Boris Mohar Guest
  2. Well, it's pretty much well-established that I'm weird, but I find it
    interesting that the French for "Power Source" is "Alimentation", which,
    in English, means "Guts", more or less. (i.e, your body's "power source".) :)
    I also once saw a pack of ramen with the instructions in Chinglish or so,
    where they called the noodles "alimentary paste". Certainly brings up
    a different image in English! ;-)
    Cheers!
    Rich
  3. Eeyore
    Eeyore Guest
    A zener stabilised HT supply ! Astonishing.
    Graham
  4. Fred Bartoli
    Fred Bartoli Guest
    Eeyore a écrit :
    Hey, it's audio!
  5. Alimentar is the verb for feeding in Spanish, which seems appropriate
    martin
  6. Fred Bartoli
    Fred Bartoli Guest
    martin griffith a écrit :
    Same in French. Alimentation has nothing to do with guts, except that
    some might pass through.
  7. I used a string of NE-2's for a geiger counter anode supply I built 30
    years ago. Worked pretty darned well. Still works.
    Jon
  8. Boris Mohar
    Boris Mohar Guest
    How would you crudely level 300V regulate do it at comparable cost?
    The service tech told me that is where the problem might be because it is
    making popping sounds. Tubes are ok. I heard about noisy zeners. Is there a
    good brand that is not as susceptible to this behavior?
  9. Genome
    Genome Guest
    Kring Hell.....
    I'd be inclined to break the circuit diagram down into functional blocks and
    do one of them there top down documentation things. Having said that, if the
    designer knew his circuit then it does look like he/she has spent a bit of
    time wrestling with stuff to give you a bit of quality.
    Wouldn't be Vutrax now?
    The 300V looks like it supplies the low level stuff and.......
    Oh Crap!!!!!
    This is part of an Eeyore Thread.
    You want to watch yourself.
    Chances are.
    1) Someone else designed it, fucked it up, he ripped it off and fucked it up
    worse.
    2) Someone else designed it, he ripped it off and fucked it up.
    3) He designed it and fucked it up.
    Do NOT under any circumstances attempt to enter into a meaningful discussion
    with this person.
    All technical advice will be rendered into an 'impressive' presentation that
    will demonstrate to the less intelligent people on the planet that Eeyore is
    the main man and.......
    He will **** it up again.
    DNA
    "A zener stabilised HT supply ! Astonishing."
    "How would you crudely level 300V regulate do it at comparable cost? "
    "I have a circuit that would perform the same function with much lower noise
    and cost with improved reliability.........."
    blah
    blah
    blah
  10. Phil Allison
    Phil Allison Guest
    "Fred Bartoli"
    ** No it is not "audio" in the usual sense of that term.
    Musical instrument amplifiers are sound ** creators ** - so a form of
    electronic music instrument.
    The industry title is " stage equipment " as distinct from PA, recording or
    broadcast equipment.
    ....... Phil
  11. Phil Allison
    Phil Allison Guest
    "Eeysore".
    ** Well - it isn't and so it isn't.
    The 300 volt low current supply is regulated by a series pass transistor.
    The zener string just provides a voltage reference.
    NOW:
    That IRF830 current limiter in the main 410 volt supply * IS * a real eye
    opener !
    Goes where no thermionic rectifier tube has gone before.
    ......... Phil
  12. Fred Bartoli
    Fred Bartoli Guest
    Phil Allison a écrit :
    He he, I know.
    Was just pulling Eeyore's trousers but it seems you share the same. Do
    you have the right leg and Eeyore the left, or is it the reverse?
    Must be pretty uncomfortable.
