Eurotherm 601 inverter
Discussion in 'Electronic Basics' started by lexuscol, Oct 10, 2003.
  1. lexuscol
    lexuscol Guest
    I have an eurotherm601 inverter rated 1/2 HP connected to an 1/2 hp motor
    1450rpm, does anyone know how I can work out the motor rpm at a given
    frequency? I.E what does 30 cycles relate to in rpm. hope someone can help
    Regards
    Col
    BabyTyro
  2. JeffM
    JeffM Guest
    Frequency counter & strobescope.
  3. lexuscol
    lexuscol Guest
    As I am only a beginner I think you could explain in a bit more detail please.
    Regards
    Col
    BabyTyro
  4. JeffM
    JeffM Guest
    Connect the frequency counter to the electrical output.
    A strobescope is a flashing xenon light
    with a calibrated dial for rate adjustment.
    Point it at the rotating device.
    Compare the 2 numbers.
  5. lexuscol
    lexuscol Guest
    Thankyou for your advice. I will try it
    BabyTyro
