gulftown17
- Apr 9, 2015
- 11
- Joined
- Apr 9, 2015
- Messages
- 11
I happen to have 2 ESR meters, the first is JINGYAN MESR-100 and the second one is Transistor L/C ESR Tester (you know that one with atmel microcontroller and it can measure resistance, capacitance, diodes, inductance, transistors etc). The problem is that they show different values. For example when I try to measure the ESR of 100uF 25V capacitor, the MESR 100 shows 0.19R and the Transistor L/C ESR Tester shows 0.30R. Just for your information I am using the pin headers and I dont use any wires to connect the caps. Which of these value is more accurate? You might recommend me to connect a small value resistor, but the problem is that the L/C ESR Tester detects it as a resistor a measures it differently than it would measure a capacitor. So which of these numbers can I trust?
Thank you
(I attach a picture of both of these meters)
Thank you
