ESR meter
Discussion in 'Electronic Repair' started by danbob5, May 30, 2005.
  1. danbob5
    danbob5 Guest
    I built the poptronics esr meter with a FAR circuit board. when i check a
    regular cap it works as it should but when i check a electolitic it
    generates about 5 to 10 % more voltage at the meter than when the probes
    are touched and the meter is zeroed out. I have checked all componet
    location & polarity 3 times and the voltages are good checked with meter &
    O scope. any ideas?
    Dan
  2. Bob Parker
    Bob Parker Guest
    The first Poptronics article was absolutely riddled with drafting
    errors. Later they brought out a lot of corrections. Have you
    incorporated those corrections into your meter?
  3. Antti Panula
    Antti Panula Guest
    Please consider buying an EVB ESR meter. This piece of equipment is great. I
    don't know what is your purpose of checking ceramic or polyester caps
    because they almost never wear out. Regular ohm meter should be fine for
    those.
    http://clientes.netvisao.pt/greenpal/
    Antti
    OH7GLS
