ESP8266 boot failure
Discussion in 'Microcontrollers, Programming and IoT' started by Dada Krauter, May 23, 2015.
  1. Dada Krauter
    Dada Krauter
    28
    Feb 22, 2015
    I have problem with my ESP8266 wifi module.
    That's my connection:
    ESP VCC > 3.3V Arduino
    ESP CH_PD > 3.3V Arduino
    ESP GND > GND Arduino
    ESP UTXD > TX Arduino
    ESP URXD > RX Arduino
    Baud rate: 115200.
    When I power on arduino, red light(power light) on ESP lights up and blue light blinks two times. In terminal im getting "Invalid" not "Ready".
    What can I do?
    Plese help me.
  2. Anon_LG
    Anon_LG
    453
    117
    Jun 24, 2014
    In serial communications the TX has to be connected to RX and vice versa. I believe this will solve your problems. If not, I am sure another forum member will be along shortly to disagree with me.
    Hope this helps,
  3. (*steve*)
    25,385
    2,772
    I think the board you're using may require more current than the regulator on an sink board can supply. Check this and use an external regulator if required.
  4. Dada Krauter
    Dada Krauter
    28
    Feb 22, 2015
    Lavaguava> thats not problem with serial communication when i swap tx and rx im not getting data in terminal.
    (*steve*)> I think you are right. ill try external regulator and ill check again.
    Thanks. ;)
