Equivalent parts - need of help
Discussion in 'General Electronics Discussion' started by velsaravanan, Jul 31, 2013.
  1. velsaravanan
    velsaravanan
    Jul 31, 2013
    Hi Guys,
    I am looking for an equivalent replacement for the following
    1 x OA47 diode
    1 x 3V0 zener diode (type BZY88)
    I couldnt find exact ones, so can any one suggest something equivalent and one I can find easily.
  2. GreenGiant
    GreenGiant
    842
    7
    Feb 9, 2012
    for the OA47 that is a 30V rated diode rated at 110mA and a voltage drop of 450mV, I can only find surface mount replacements but I dont have the time to do a lot of digging.
    You can find the Zener right here for really cheap, all I did was google "BZY88 3V0"
  3. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    It depends on where you are. In the UK, both are available on e-bay.
    The OA47 could perhaps be replaced by a Schottky diode.
    3.3V seems to be more common than 3.0V.
    Is your circuit fussy?
  4. techiesteve
    techiesteve
    17
    Jul 27, 2013
    Suggesting a substitute for the OA47 would be easier if we knew in what and where it was used. The designer may have simply specified an OA47 as a general purpose diode as it was current at the time of the design. The spec could turn out to be flexible unless its characteristics were critical to the circuit.
    Steve
