Equivalence IC 3PIN K2524 - Help Please ;)
Discussion in 'Electronic Repair' started by [CORRAD], Jul 30, 2004.
  1. [CORRAD]
    [CORRAD] Guest
    my need an equivalence (compatible substitute) of IC (3PIN) TO220
    (ISOWATT) K2545
    Thanks to all those that will help me
    PS Sorry for my English
  2. Zeljko
    Zeljko Guest
    Are You sure it's IC?
    Common designation is K2545=2SK2545 - japanese MOSFET
    2SK2545=
    Metal oxide N-channel FET, enhancement type with diode
    V-MOS, 600V, 6A, 80W, <1,25ohm(3A)
    Comparison types:BUZ 91, 2SK1117, 2SK1924, 2SK2140
    Pinout: G D S looking from left, normal orientation
  3. Chaos Master
    Chaos Master Guest
    [CORRAD] caused an illegal operation in module
    2SK2545 mosfet?
    www.google.com/search?q=2sk2545
    [PDF] 2SK2545 PDF/Adobe Acrobat
    2SK2545 2002-09-02 1 TOSHIBA Field Effect Transistor Silicon N Channel MOS
    Type (p-MOSV)
    2SK2545 DC-DC Converter, Relay Drive and Motor Drive Applications ...
    www.semicon.toshiba.co.jp/docget. jsp?pid=2SK2545&lang=en&type=datasheet
    []s
  4. [CORRAD]
    [CORRAD] Guest
    "Zeljko" <> ha scritto nel messaggio
    [CUT]
    Good information,
    Thanks! ;)
  5. [CORRAD]
    [CORRAD] Guest
    [CUT]
    thanks!
