Epson Tm U295
Discussion in 'Datasheets, Manuals and Component Identification' started by rbetroy, Oct 8, 2007.
  1. rbetroy
    rbetroy
    Oct 8, 2007
    We Are Trying To Figure Out The Serial Pinout Configuration From 25 Pin (serial Printer) To Db9 Connection (serial). Trying To Collect Ascii Data From This Port. However Eventually Our Connections Will Be At Both Ends Of The Cable Db9 Connectors. Currently When Using A Slip Printer To The Pos The Cable Would Be Connected To A Db9 Com Port Coming Off Of The Cash Registers, And A Db25 Going Into The Epson Tm U295 Printer.
    The Pos System Is A Toshiba Ma1595 (9 Pin (db9) Comports)) And The Printer Is A Db25 Pin. We Are Not Using A Printer, But A Software Based Data Collector To Simulate The Transactions. We Are Trying To Figure Out The Pinout Configuration So That We Can Develop A Cable That Will Allow This To Work Properly.
    The Cash Register Is Set For 9600 Baud Rate, 8, None, And 1 And
    A Slip Printer Is Normally Attached (as Listed Above) But We Are Using A Simple Windows Based Data Collector. Normall Works With Other Pos Systems No Problem.
    Does Anyone Have Any Knowledge Regarding The Above. Tm-u295 Serial Printer And Using A Toshiba Ma 1595 Register Rear Panel Db9 Com Ports.
Similar Threads
Loading...
