Hi folks... haven't posted here in years, but I'm attempting to troubleshoot my Epson Artisan 835 all in one printer.
It's about 10 years old so it's served me well. Today I printed a couple pages, then after it finished and it went into its cleaning/parking cycle it started powering itself off and back on, over and over. My initial guess is capacitors failing, because of course, that's usually what goes bad in modern electronics right?
Well, being a modern Epson printer, they didn't make it easy to take apart, but I was able to get it apart enough to get the power supply module out. I opened it up, and visually everything looks fine. No bulging or leaking caps, no burnt anything, looks pristine in fact. So, I don't know if it's good or not.
I did find a service manual online, surprisingly enough, and even more surprisingly, the PSU output voltages are 42 volts. There's a 6 pin header, and according to the service manual, "Pin 1 - pin 4" should read 42.0V and "Pin 2 - pin 5" should also read 42.0V, and they do. Pins 1-2 are connected together and are the positive rail and pins 4-5 are both ground.
Interestingly, pin 6 has some circuitry connected to it and I get a different voltage there, but the service manual makes no mention of that pin, its purpose or what voltage to expect on it (I get 40.8V relative to pins 4-5 which are ground, and 1.32V relative to pins 1-2).
I suppose I should try testing it under load, but I doubt the printer will function without breaking something if I reconnect the PSU and power it up while it's in its present state of partial disassembly.
Perhaps, considering the 42V output of the power supply, there's another power regulator/supply on the main board and its caps are the bad ones? I guess I'll have to figure out how to get the printer apart enough to find and pull the main board. Time to read the service document I downloaded, LOL.
I'm wondering if I should suspect any of the caps in the PSU even though they look fine. I tried measuring them with my DMM but it won't read capacitances that high. The PSU has two 1500uF 50V electrolytics (probably low ESR ones?), one 180uF 200V electrolytic, plus a smaller 47uF 35V cap.
Should I bother replacing them? Test further? Try and get the main board out? This is one of several projects I have going on so no rush. I have some new test leads/probes coming from Amazon which will make testing things in circuit easier, I can do more troubleshooting once those arrive.
Attached is a pic of the PSU board. Only thing that appears visually "off" is some missing paint on the one blue/gray resistor at the center of the board. There's no sign of overheating otherwise.
Thanks...
Thanks...
