Epson 5.25" floppy drive alignment
Discussion in 'Electronic Repair' started by Matt Carpenter, Nov 15, 2003.
  1. I'm attempting to restore an old Kaypro IIx with Epson SD-521 5.25" floppy
    disk drives (DSDD).
    One drive works fine, but the second drive is misaligned. I just purchased
    an analog alignment diskette but I'm not sure which test points should be
    used.
    On the drive there is a set of three pins marked TP1, another set of three
    pins marked TP2, and a single pin labeled TP3.
    I'll need to find both head signals to adjust the radial head alignment, the
    index sensor signal to test the index sensor, and the track 0 detector
    signal.
    Are floppy drives standard enough such that they use the same names for the
    test points? Or, does someone know how/where I could find documentation on
    this drive?
    Finally, what exactly is the f and 2f signals on the alignment disk?
    Thanks, Matt
    [mkath at charter dot net]
