EPICPlus programmer and PIC 18F452 problem
Discussion in '8bit Microcontrollers' started by Marty Vezina, Nov 2, 2003.
  1. Marty Vezina
    Marty Vezina Guest
    This is the first time I have tried to program a set of three PIC 18F452
    I recently purchased and I can not get a simple LED flasher to work.
    The PIC BASIC Pro code works fine with a PIC 16F628.
    The code downloads and is verfied ok on the 452 using the latest version
    of EPICWin with the EPIC Plus programmer.
    I believe my problem has to do with the settings within the EPIC
    programming software. I found a reference to the need to erase the 452
    before programming, but I am not sure of any other settings.
    The clock source is a 20Mhz crystal.
    I am hoping that someone could tell me what the minimum settings would
    be... actually any help would be great!
    Thanks - Marty
