Environment-resistor temperature
Discussion in 'Electronic Basics' started by signo, May 25, 2005.
  1. signo
    signo Guest
    Hello to everybody, first of all sorry for my English (I'm Italian).
    I have a circuit, enclosed in a plastic box, where there is power
    resistor 1K, 50W and Tmax=200 degrees centigrade.
    On the resistor is not present any heat sink.
    After few hours that the circuit is working, the temperature measured
    on the case of the resistor (Tr) reaches 110 degrees, in a
    environmental temperature (Te) of 20 degrees.
    My boss says that if Te increases50 degrees (Te = 20+50 =70 degrees),
    Tr will increase the same value (Tr = 110+50 = 160 degrees).
    I would say that Tr will increase, but not so much, just a little bit.
    In my opinion it will be reduced the time for the resistor of reaching
    the maximum value.
    Is my boss right? Am I right? Are we both wrong?
    Thank to everybody is going to help me about this matter.
    Massimo
  2. Ban
    Ban Guest
    Massimo,
    your boss is right, what counts is the temperature difference. You shouldn't
    distrust an engineer so easily, (that's what I suppose he is). :))
  3. signo
    signo Guest
    well... to be honest he is not an engineer, I'm an engineer.. I am
    deeply ashamed...
  4. I suspect that the approximation attributed to
    Massimo's boss is the most useful one to be made.
    However, it must be recognized as nothing more
    than an approximation. The heat loss mechanisms
    do not have an inherently linear relationship between
    heat flow and temperature differences. For example,
    convection loss partially depends on radiation which
    varies with the 4th power of absolute temperature.
    Chimney effect can cause more air flow and thinner
    boundary layers through which the heat must flow
    for convection cooling.
  5. Minor correction inserted below.
    Should be:
    total heat loss partially depends on radiation which
  6. Ban
    Ban Guest
    Unfortunately you cannot rely on the radiation, it will be a miniscule
    amount compared to the convection, because he says the box is closed, so
    radiation can only be from the outer surface, which he didn't report. I
    presume it will be half way between inside and outside, if the surface is
    0.1mq and e=0.8, then with 338K 0.55W is radiated and with 408K 1W is
    radiated, hardly much in comparison to the total power, but it makes a good
    excuse to the boss. THX to Larry
    The formula to impress the boss:
    surfaceArea(m^2) * e(0.5...1) * constant 5.67e-8(W/(m^4 * K^4)) *
    (emitterK^4 - ambientK^4)/(emitterK - ambientK)
  7. About the most I can say is that Tr will not rise more than Te does,
    though it is possible that Tr will rise almost as much as Te does. At
    low temperatures (low not being defined) heat is transferred primarily
    by by conduction and convection. Conduction is a fairly linear
    process that passes energy with a temperature rise about proportional
    to the energy flow. Convection is also fairly linear. But in
    parallel with these two mechanisms is radiation, and it is decidedly
    nonlinear. Radiation passes energy in proportion to the 4th power of
    absolute temperature difference. So as the temperature of box and
    resistor rise, there is some absolute temperature at which radiation
    will overtake both conduction and convection as the dominate transfer
    mechanism. I don't know if that temperature is any where near the
    temperatures you are talking about, however.
    So your is correct, in the limit for low temperatures, and you are
    right above some particular temperature. An experiment is the best
    way to settle this argument.
  8. signo
    signo Guest
    Yesterday I've tried to test Tr with Te variable (from 20 degrees to 35
    degrees).
    I can say that, with a tollerance of one degree, approximately the
    variation of Te is the same of the variation of Tr.
    Thanks to everybody,
    Massimo
