E
Evad Remlu
I bought the Energizer 15 minute NIMH charger for 27 USD at Wal-Mart with 4
each 2300mah batteries.
This is a very high-tech device with a 12 volt switching power supply and
zillions of smt devices inside. It will charge cells individually and its
most obvious feature is a fan located under the charging compartment. It can
be powered directly from a 12 volt car system.
To say that the batteries get HOT during a fast charge is an understatement.
They get too hot to touch! It charges AA batteries at 7 amps! I think the
fan is a bit weak for this application. I wonder if I could put a more
powerful fan in it?
After a few weeks of using this thing I have considered the unit 'pretty
good' but not perfect. It sometimes recognizes fully charged or partially
charged batteries as bad and won't charge them. Older batteries seem to need
'conditioning' before they will accept a fast charge. The individual cell
charging opens up the possibility that all cells don't get charged equally.
After fast charging in this unit, I can put the cooled cells into my old
Maha charger and it takes about an hour to go 'green' and say they are
really full. This leads me to believe that it doesn't always completely
charge the batteries.
One old off-brand battery spurted fluid when fast charging in this unit.
I wonder how many fast-charge cycles the new 2500mah will take using this
unit. I will let you know.
Evad
powerful fan in it?
Evad
