Emitter Base Breakdown
Discussion in 'General Electronics Discussion' started by duke37, Feb 28, 2013.
  1. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    What happens to the collector current of an npn transistor when the permitted base emitter reverse voltage is exeeded.
    Using LTspice for a BC547B does not allow for junction leakage. The base voltage goes to -100V with no limit.
  2. BobK
    7,682
    1,688
    Interesting question. I thought exceeding that voltage would damage the transistor.
  3. john monks
    john monks
    693
    Mar 9, 2012
    Just for duke37. I just tried the experiment with a 2N2369A. I don't have a BC547B.
    I used a 12 volt supply.
    I used a -12 volt tail generator 50 ohm output impedance.
    Rc is 1k.
    Rb is 1k.
    I supplied a -12 volt tail pulse to the other end of Rb. The transistor base emitter conducted at about -7.5 volts and the collector remained at 12 volts continuously.
    I removed Rb and the collector started getting about a negative 30mv pulse riding on a 12 volt baseline.
    So your answer is essentially nothing.
  4. duke37
    duke37
    5,364
    772
    Jan 9, 2011
    Thank for the replies and the experiment.
    Reverse current through the emitter/base junction will not necessarily create damage. I have a Heathkit HW100 transceiver which uses a transistor junction as a Zener diode.
    Duke
  5. BobK
    7,682
    1,688
    I guess it depends on the amout of current!
  6. john monks
    john monks
    693
    Mar 9, 2012
    duke37, you are quite right. In fact I built a 1000 volt power supply for the purpose doing high voltage experiments with semiconductors running transistors in the avalanche and testing the reverse characteristics of diodes. I discovered that practically no PN junction is damaged by running in the avalanche mode at reasonable power levels. In fact I discovered that the 1N4152 and the 1N4154 make good 90 volt zener diodes.
    So in many ways semiconductors are very forgiving.
  7. (*steve*)
    25,497
    2,838
    Here is an interesting document that discuses the potential for failure.
  8. john monks
    john monks
    693
    Mar 9, 2012
    Very interesting document. I am looking at the damage characteristic plots and I see that some of there devices were powered over 1 million watts before failure. The transistor plots seem to be close to what I got although I used different transistors.
    These plots are very important because in the pulse generator business your running parts well outside of the maximum specification in order to get minimum widths and maximum power levels without failure. Thanks steve.
  9. EinarA
    EinarA
    28
    Feb 11, 2013
    Breakdown of the BE junction does damage the transistor , the beta is permanently decreased every time this happens. Transistors make excellent zeners: the knee is much sharper but the voltage varies widely from one device to another even within the same type. I have read that you can measure a small negative voltage at the collector, supposedly from IR light from the Zener. Another use is as a white noise source, a2N2222 produces a very strong signal with other types much softer.
  10. john monks
    john monks
    693
    Mar 9, 2012
    EinarA, where can I get more information on the damaging affect of a reversed BE junction and the IR affect on the collector voltage? I never thought about the IR.
  11. Harald Kapp
    11,522
    2,654
      File size:
      4.4 KB
      378
  12. john monks
    john monks
    693
    Mar 9, 2012
    That's interesting but I was mainly interested in the statement that EinarA made. He said that breakdown of the BE junction does damage the transistor, that this reduces beta. I have not seen this and I have not read that anywhere else. If this is true it is worth it for me to research this. I'm in an industry that uses this effect to create random noise.
  13. (*steve*)
    25,497
    2,838
    I have heard the same mentioned as well. However I have not been able to find any documented evidence of it.
    I suspect that one method for this to occur is due to localized heating of the junction whilst conducting in the reverse direction.
    Potentially this could cause migration of doping atoms, or perhaps even damage similar to secondary breakdown.
    But all of this is conjecture (by me) and I would not dismiss other theories (or indeed accept these) without some good evidence.
    If anyone can find some, I'd be very interested.
    edit: This looks like it could be interesting. And this has some background.
  14. EinarA
    EinarA
    28
    Feb 11, 2013
    John, I'm not sure where I read about the photoelectric effect, it might have been in one of Bob Pease's columns. I don't know why no one is turning up references to beta reduction as this is well known in the professional literature.
  15. john monks
    john monks
    693
    Mar 9, 2012
    I intend to run the base emitter junction of a transistor in the zener mode over the weekend and see if the beta degrades. I intend to report back. I suspect it won't.
  16. EinarA
    EinarA
    28
    Feb 11, 2013
    Why should I bother to post anything if no one believes it. This effect is well reported in real engineering magazines and has been tested by me. To get the data given in the first post I tested about 6 transistors. I didnt test all for beta loss, but two 2N2369s started out at 60 and only measyred 20 when I finished.
  17. john monks
    john monks
    693
    Mar 9, 2012
    Sorry, You see I work on transistor circuits that run in the avalanche mode, the zener mode, and very high current pulse mode. It is important for me to know if something is going to fail. I suspect that you drove the 2N2369s with much more current than what I am doing in our company. I drive them with a few hundred microamps. Now I am testing a 2N2369A with about 7 milliamps in the zener mode. I started out with a beta of about 30 and I will measure it again Monday. I thank you for the information.
  18. EinarA
    EinarA
    28
    Feb 11, 2013
    You can take it out and measure it right now. The damage is done in the first instant. My notebook records show voltage at 1,10, and 100 uA. P S One of those transistors now measures 15. I'm not willing to test any of the 2222s I use for noise sources as I solder B to C so the matel can acts as a shield, but I think this transistor is less affected.
  19. (*steve*)
    25,497
    2,838
    If we didn't believe you, this thread would have been much shorter.
    I have speculated on the cause. I am skeptical that it happens at any reverse current, but skeptical means that I'm willing to be shown to be wrong.
    As I said, I've heard of it but I've not seen any references. If you can point us toward any it would be really interesting.
    And indeed there are people here trying it for themselves.
    Sorry, I can't quite figure what went from 60 to 20? Was it the small negative voltage on the collector?
    Going back to your original question, I think you need to test this with real rather than simulated components. The operating region is so far outside where (I suspect) the model is valid that I wouldn't trust it.
    An interesting note earlier about IR emitted from the junction. having a photoelectric effect on the other junction. Not something I would have considered.
  20. EinarA
    EinarA
    28
    Feb 11, 2013
    You don't seem very willing to be " shown to be wrong " if you have rejected everything I have said so far. It should be obvious to anyone that the beta dropped from 60 to 20. Why are you claiming that this is only simulation data when everyone else has said it can't be simulated. I'm sorry I brought this up, I don't care to have my knowledge subjected to the ignorance of others. And no, you don't have to worry about me calling you 'sir'.
