W
Watson A.Name - \Watt Sun, the Dark Remover\
Yea,they probably were higher than 20 feet,but MAN they look LOW..
It's funny when you see the wires up close,and realise that the "little"
cables up there are like 4 inches diameter! (and there's 3 cables per
conductor/phase,connected together with Y shaped pieces.)
The high tension lines that terminate here locally in a huge switchyard
come across the desert and mountains from Hoover dam and Lake Mead.
They were adding more conductors and the new ones were laying on the
ground, so I went over to the fence to check them out. They were about
1.3" (33mm)in diameter, and must weigh several pounds per foot. There
are six aluminum strands around a center steel strength member. Each
insulator holds two conductors. I think the insulator is longer than 6
feet. But they say that the closer the lines are to the ocean, the more
insulators they add, because of the salt in the air.
