emerson dvd player
Discussion in 'Electronic Repair' started by ee_design, Nov 14, 2006.
  1. ee_design
    ee_design Guest
    A "friend" gave me an emerson dvd/vcr combo player that works fine
    EXCEPT it won't eject the dvd. It will close the drawer fine if it is
    open and it can be opened manually from inside the machine and then it
    will respond to command to close. I have looked for some sort of sensor
    that reads the drawer closed assuming if it doesn't know it is closed
    it won't open but I can't see any. Any ideas?
  2. David Naylor
    David Naylor Guest
    you have a driver ic that has gone south or look for a puffy cap near
    the ic just follow the wires that go to the loading motor and you will
    fid the ic it might have a small heat fin on it
