Embedded ethernet
Discussion in 'Electronic Design' started by devang, Feb 21, 2007.
  1. devang
    devang Guest
    Dear All,
    I am trying to implement ethernet using any microcontroller may be 8
    bit or 16 bit.
    I have come across some ready made ethernet to ttl converters but, I
    need to develope on my own, i.e. using microcontroller and some
    interfacing circuit.
    Can anybody suggest any microcontroller and / or interfacing chip??
    I need a direction to start my project in particular direction.
    Thanks & Regards,
    Devang Tanna
  2. John Barrett
    John Barrett Guest
    Just to make sure I understand what you are asking, you dont want to use ANY
    off the shelf ethernet chipset ?? you want to basically hook up an AVR/PIC
    to a 802.3 PHY layer and do all the link layer in code ?? Or are you talking
    about implemeting the PHY yourself ??
    here is an example of a PHY for 802.3
    http://www.teridian.com/products/product_detail.cfm?product_key=74
    Is that what you want to build, or does that get you what you need to work
    the higher layers in the microcontroller ??
  3. John Barrett
    John Barrett Guest
    I just did a little research -- if you are trying to implement a PHY, you
    need to go talk to the DSP people.. There isnt a microcontroller anywhere
    near fast enough to handle what a PHY does by any stretch of the imagination
    If you are looking to implement the 802.3 MAC, there is an example at
    http://www.opencores.org for CPLD devices which might give you enough info
    to write a MAC for a microcontroller. However, I dont think any of the 8 bit
    controllers (AVR or PIC) could handle the job.. you'll need something with a
    much higher clock speed and better synchronous serial I/O capability than
    you can get in any 8 bit chip, and even then, dont bet on being able to
    handle anything more than 10 megabit... you need to implement the guts in
    hardware if you want to go faster than that.
  4. You can make life a bit easier for yourself with the W3100A:
    http://www.wiznet.co.kr/pro_iin_W3100ALF.htm
    Or buy a complete module iiM7000 (came with a RJ45 connector and magnetics in my case):
    http://www.mcselec.com/index.php?pa...age&product_id=24&option=com_phpshop&Itemid=1
    Also the C sources for TCP server etc. for this module are freely available
    on the net.
    Watch out, there is a (later) I2C, and a non-i2c version of the IIM7000 IIRC.
  5. devang
    devang Guest
    Dear All,
    thank you very much for your replies.
    I want to basically connect my project to TCP / IP or UDP network. I
    dont have much idea of doing it how to do it.
    The only thing I know is i cant use any ready made ethernet to ttl
    converter. so yes I want to implement ethernet circuit and code on my
    own. I do have some basic knowledge of tcp/ip protocols with code.,(I
    have a reference book for that). but i dont know exactly where to
    start.
    I think I will try to research more on the links you all have provided
    and will let you know about exact requirement.
    Thanks & Regards,
    Devang Tanna
  6. Paul Burke
    Paul Burke Guest
    Oy is that all. Try this: http://tinyurl.com/3dyy8e
    Paul Burke
  7. John Barrett
    John Barrett Guest
    Isnt that a "ready made ethernet to ttl converter" ??
  8. Bob
    Bob Guest
    In my opinion no, it requires mounting on a circuit board with a
    seperatly purchased transformer
  9. ISTR there is already a project out there - tiny Ethernet or something like
    that?
  10. Paul Burke
    Paul Burke Guest
    Well, it's CMOS for a start, and it requires transformers on the net
    side... but I suppose "TTL" (*) means "logic of any sort" in these
    dumbed down latter days. OK, if you have to make trouble, get hold of an
    eZ80F91 devkit and a KS8721 or something, and implement one of the
    examples that come with the network stack. For what you'll learn (if it
    is a college exercise) I can't see the difference really.
    Paul Burke
    (*) Grumble grumble... all that time spent learning why TTL was faster
    but had worse noise margin, if you want an industrial system use 15V
    4000 series or better still those Norbrick chunks.
  11. skenn_ie
    skenn_ie Guest
    PIC18F**** and ENC28J60
  12. devang
    devang Guest
    Dear friends,
    Thank you very much for all the responses.
    I have also been watching enc28j60. that is the best ethernet
    controller available which is spi enabled and have builtin phy and mac
    within it. I referred it datasheet for my application.
    I think it will suit my requirements.
    Now , i came to know that it does ethernet framing on its own, which
    is again an advantage.
    But how can I communicate with PC? using ENC28j60? I mean do i need to
    implement TCP/IP Stack with that????? I need tcp/ip and udp protocols
    for that. is source code available with microchip website?
    I downloaded tcp/ip stack 4 but I dont understand exactly how to use
    it.
    can anyone help me, please..........
    Best Regards,
    Devang Tanna
