G
Green Xenon [Radium]
Hi:
I remember reading somewhere than ELF [Extremely Low Frequency] radio
transmission is inefficient because it requires to much power.
If that is the case, wouldn't MW [Medium Wave] radio transmission
require even more power?
MW and ELF are forms of electromagnetic radiation in the RF spectrum.
An photon [or electromagnetic wave] of a higher-frequency has more
energy than a photon of a lower-frequency.
Let's say there are there are two radio transmitters, one emits 2 GHz
waves while the other emits 2 kHz waves. If the two radio transmitters
use the same modulation scheme [AM/FM, etc.] and emit the same amount
of photons-per-second-per-square-meter, the 2 GHz transmitter will be
using more watts than the 2 kHz transmitter -- because a 2 GHz photon
requires more power to generate than a 2 kHZ photon. Right?
So how would transmitting a lower-frequency radio wave require more
power than transmitting a higher-frequency radio wave?
Radium
Radium
