Jack
(Response to Petrus Bitbyter in sci.eletronics):
Original message:
I constructed the EPROM Emulator published in Elektor magazine in the
SEPTEMBER 1992 issue. It worked quite well under Win98, but lately I
started using it on a HP Compaq nx9010 Pentium 4 laptop using WinXP,
and am getting inconsistent results. The downloading of code into the
target works successfully 1 out of 10 attempts. When the download
fails, the download LED flickers on and off. When the download was
successful, the LED stayed on continuously.
Any ideas? I tried changing the parallel port mode on the laptop to
Output Only, Bidirectional, EPP and ECP but no change.
Follow-up:
I might be referring to the wrong Elektor article - the article I
referred to is the one NOT using a Windows driver, i.e. I download my
object code using a DOS command line copy command in binary format
i.e.
copy <8051 object file> lpt1 /b
Regards
Original message:
Follow-up:
i.e.
Regards
