Elektor Electronics.
Discussion in 'Electronic Components' started by ian field, Aug 25, 2007.
  1. ian field
    ian field Guest
    The September issue was supposed to include a free LED driver PCB - mine
    didn't!
    Can anyone describe to me how it was attached? This is not the first time
    Elektor has arrived sans freebie and as usual the newsagent vigorously
    denies any knowledge of it - I'm starting to suspect foul play!
    TIA.
  2. Well, the picture is on the cover and the description inside. The pcb
    measured roughly 16x11mm and most of them had the top of the coil damaged.
    It was packed in a just fitting, plastic bag which was glued to the cover.
    As the issue itself - including the pcb - was wrapped in its plastic it is
    unlikely it get lost accidentally.
    petrus bitbyter
  3. Don McKenzie
    Don McKenzie Guest
    I would suggest if the magazine wasn't in the plastic cover/envelope,
    you contact the publisher. They won't be happy if the magazine has been
    tampered with after publication and distibution.
    Don...
    Don McKenzie
    Site Map: http://www.dontronics.com/sitemap
    E-Mail Contact Page: http://www.dontronics.com/email
    No More Damn Spam: http://www.wizard-of-oz.com
    Serial OLED uses standard micro-SD memory cards.
    http://www.dontronics-shop.com/product.php?productid=16659
    USB Flash Drive interface for existing products.
    http://www.dontronics-shop.com/product.php?productid=16654
