electronics question
Discussion in 'General Electronics Discussion' started by flyingphil, Nov 4, 2010.
  1. flyingphil
    flyingphil
    Nov 4, 2010
    Is it possible to increase 0.5 amps to 3.5 amps using aimple amplifying circuit.
  2. LTX71CM
    LTX71CM
    182
    May 23, 2010
    Short answer. No. If you can tell us what you're trying to do can can give you a better, longer answer.
  3. flyingphil
    flyingphil
    Nov 4, 2010
    simple amplification
    ok is it possible to double volts and amps at the same time, etc 10v to 20v and 1amp to 2amps, (10v 1 amp to 20v 2 amps) using a simple circuit.
  4. LTX71CM
    LTX71CM
    182
    May 23, 2010
    No. The energy available will always be the same. You can transform it, but not create it.
  5. KMoffett
    KMoffett
    723
    75
    Jan 21, 2009
    ...no...
    Ken
  6. davenn
    davenn Moderator
    13,765
    1,920
    in fact the opposite, if you double the voltage , you are going to halve the current available
    as LTX71CM the energy (Power) available doesnt change
    that is if you have a power supply capable of supplying 100Watts. that can be 20V @ 5 amps or 5V @ 20 amps or any variation there of. Whatever you Volts and Amps they have to equal 100W max when multiplied together.
  7. (*steve*)
    25,473
    2,819
    Yes, this is quite simple. BUT the circuit will require it's own power supply capable of providing the full output voltage and current you require.
