Electronics problem pls help
Discussion in 'General Electronics Discussion' started by needs, Mar 31, 2010.
  1. needs
    needs
    Mar 31, 2010
    hi
    I have a problem with an electronics amplifiers equation. The equation is IB(base current ) = IL(peak load current)/(1+β)
    what does 1+β means?
    pls help and thanks
  2. (*steve*)
    25,389
    2,774
    Google (and in this case wikipedia) is your friend.
  3. aosodo
    aosodo
    Mar 31, 2010
    hi where is the the menu button on toshiba2909xh. antony
  4. neon
    neon
    1,325
    Oct 21, 2006
    beta is just a number assigned to a particular Ic it means nothing except for insurance that there is enough gain at that particular current Ic. beta on a transistor can vary from 10 to 200 it all depends on the load curve
