M
Marshall Dudley
Does anyone have any information or know a link on the specifications
and characteristics high frequency electronic neon sign transformers? I
have an unusual application where I need an AC square wave of around
3-4KV with a dwell time between the pulses. From looking at the limited
specifications from some of these units it appears that is what they
produce, but I can find no information on the actual peak amplitude vs
their "rms" equivalent amplitude (they will not be the same if there is
dwell time), on/off or dwell ratio, and method of current limiting (drop
in voltage or reduction in "on" time). Also their specifications make
no sense, for instance the one limited specification I could find claims
that a 3 KV RMS unit has about a 4.5 KV peak to peak voltage, which is
impossible, a square wave which would have the lowest ratio would be 6.
KV peak to peak.
Marshall
KV peak to peak.
Marshall
