R
René
I am looking for an electronic model of a membrane pump:
One side of the membrane is controlled with a constant pressure gas,
which is being switched on, and vented periodically.
On the other side of the membrane a fluid is being pumped (using 2
valves to give the fluid direction.
So far most things can be modelled in "electrical" form (P = V, I =
Flow etc) bet the membrane itself eludes me so far.
I firs naively thought a capacitor (diode pump config) would do, but
appearently this is not so.
For one, the membrane pump will always pump the same exact amount of
fluid each cycle, no matter what pressure is applied primarely, while
a capacitor can "pump" any amount of electrons, based on the voltage
applied primarely.
The pumping is controlled by the fact that secondarely the pressure of
the fluid remains constant, until the membrane hits the stop, after
which the pressure drops away, and the primary side of the membrane is
vented for a new cycle.
I feel stupid - but I cannot replicate this principle in an electronic
circuit......
Any pointers appreciated - TIA!
applied primarely.
circuit......
