Electronic Kit Codes BASIC
Discussion in 'Hobby Electronics' started by canibefamous, Nov 15, 2004.
  1. canibefamous
    canibefamous Guest
    Hi there
    I have brought an electronics kit which allows me to input output via the
    parallel port and the kit says to 'load basic and enter lines 10-90' what
    excatly is basic do i just use a basic compiler or what?
    if you could help that would be great
    thanks
    Nathan
  2. Dick Smith & Jaycar sell these kits.
    They probaby refer to GW Basic, though just about any language can write to
    the centronics port.
    http://www.geocities.com/KindlyRat/GWBASIC.html
    gtoomey
  3. canibefamous
    canibefamous Guest
    Hey there
    thanks for your help i will try it out
    thanks
    nathan
  4. Franc Zabkar
    Franc Zabkar Guest
    If you are using Win9x, then QBASIC can be found on the Windows CD in
    the \tools\oldmsdos directory.
    - Franc Zabkar
  5. Dingo
    Dingo Guest
    Be warned though - if using Windows NT, Windows 2000, Windows XP you don't
    have native access to the parallel port. To fix this you need to a program
    that simulate native access. Try one called UserPort. Once loaded you can
    use the parallel port without any further hassle.
    Dingo_aus
  6. canibefamous
    canibefamous Guest
    hi
    thanks fo ryour help but i did know about the port errors
    thanks nathan
  7. canibefamous
    canibefamous Guest
    hi thanks for your help
    no im not using windows *8/98 but xp i know about the parallel erros but i
    will try using GW Basic or could i get QBASIC off a win 98 disk?
    nathan
  8. Franc Zabkar
    Franc Zabkar Guest
    Yes, both Win 98 and Win 95 included QBASIC.
    - Franc Zabkar
