CWatters said:
That type is probably the most practical digital ammeter for that kind of
use but one caution. The power to run the meter has to be isolated from the
circuit being measured. They need either a battery or an isolated dc/dc
converter to power them.
You can also find some 0-10 and 0-30 amp shunts with digital displays,
though not quite as pretty or high quality, for about $12 on ebay. Also
some ready made 0-200 amp digital automotive volt/amp meters for about
$80.00.
All they are is a 200mV volt meter wired across a current shunt that
delivers voltage calibrated to the meter's range. Shunts come in all sorts
of ranges but for these cheap meters you need eithe 1,10 or 100mV/amp shunt.
For exampe to read 200 amps on a 200 mV meter you need a shunt that delivers
1mV/amp. For a 20 amp range a 10mV/amp shunt.
Glenn Ashmore
I'm building a 45' cutter in strip/composite. Watch my progress (or lack
there of) at:
http://www.rutuonline.com
Shameless Commercial Division:
http://www.spade-anchor-us.com
