Electro Leakage ?
Discussion in 'Electronic Design' started by Phil Allison, Mar 7, 2008.
  1. Phil Allison
    Phil Allison Guest
    ** Hi to all,
    I have Google searched without luck for the formula ( or even a good rule
    of thumb ) for how DC leakage current varies with temperature for common
    electrolytic capacitors - ie the usual 85C and 105C types.
    My own testing suggests it is strongly positive and increases by a factor of
    2 or more with a temp rise of 20C.
    Anyone help ?
    ........ Phil
  2. whit3rd
    whit3rd Guest
    There's strong history dependence; after storage, the oxide can
    perforate,
    and a quarter hour at max temperature and voltage makes it heal.
    The 'healing' process generates lots of nonrepeatable leakage current.
    So consistent measurement requires a temperature/bias prestress
    cycle (I've used a curve tracer and hot air blower). After that,
    the measured leakage might be meaningful . Manufacturer's data
    on leakage is ... sketchy at best. There aren't even any limits
    except
    at 25 C, in the datasheets I see.
  3. Phil Allison
    Phil Allison Guest
    "whit3rd"
    "Phil Allison"
    " Manufacturer's data on leakage is ... sketchy at best.
    There aren't even any limits except at 25 C, in the datasheets I see. "
    ** The DC leakage figures I see published are ambiguous or just plain
    wrong - particularly in relation to the temperature.
    If you apply the formula quoted ( ie 3.sq.rt CV uA) and that is for 25 C -
    then allow the leakage to rise by a factor of 5 or possibly 10 at max temp
    of 85 C or 105C - a high voltage cap will be dissipating several watts &
    EXPLODE.
    ( note " C " in the above formula is in uF )
    ........ Phil
