| thanks for the replies so far guys. the meter at my property is about
| 30years old with only 1 dial, so there is no differetiation between peak
and
| off peak.
| sometimes i feel that the elec. comp. is ripping me off by only
| 'guestimating' my usage. (my meter is not readily available to be read
| because it's behind a roller door and also i shut the front gate with a
| 'beware - vicious dog sign')
| what key words should i search for in google to find some text on this
| stuff?
Ok this is what I've summarised so far...
A. Domestic power rate does not change.
B. Off-peak power metering is turned on automatically by a tone on the AC
line and is measured on a 2nd meter.
- if so... why does my bill have a peal/off-peak tariff if I've only got
a single meter? does that mean they stuffed up my billing?
C. If I relocate the meter box, who should pay for it? It's on the carport
side of the house towards the back. There's no practical place to install
it - particularly I have to close the gate to stop the dog running away.
What should I do?
two types of metering like this I have seen
1> 2 normal meters - one is just for the normal power
and 1 for the hot water - (off peak. tariff). A 3rd enclosure (that
looks much like a meter) has a relay inside it that will cut off the
power to the hot water system at certain times (ie - peak load times).
With this system - all power used on the off peak circuit is off peak
power - but it isnt continuous power.
2. A single meter with 2 separate dials inside. The relay (or
whatever mechanism used) inside would move the drive mechanism between
the peak and off peak dials depending on the peak and off peak times.
I would assume this type is for appliances where the power is
continuously available - but if you want to use it in peak times - you
pay a premium rate.
In both cases the relay is activated by control tones that are sent
over the distribution network.
If you have only one meter - then Im certain you are paying a shitload
of $ for your hot water (if electric) as it cant be possible to meter
it separately.
Of course - they might be doing something like giving you an off peak
rate calculated on an average % of power used etc or some
unexplainable thing like that.
As far as the metering access goes - maybe you should call your
electricity supplier and ask for suggestions, also ask them about the
off peak rates etc, maybe to get them to inspect your setup and advise
as to possibly get off peak installed etc. Might save you a good
amount of money
