Electrically short antenna
Discussion in 'Electronic Basics' started by thejim, Jan 17, 2006.
  1. thejim
    thejim Guest
    I read in a book the following:
    An Electrically short antenna means that is shorter than one half
    wavelength which also means that is not resistive.
    I have 2 Qs.
    1.When it says "shorter than one half wavelength" it means the physical
    length?
    2.Why being electrically short means it is not resistive?
  2. Fred Stevens
    Fred Stevens Guest
    1) The physical length is shorter than one half the wavelength of the
    signal
    2) An antenna or transmission line which is not terminated with its
    characteristic impedance will have an input impedance which has phase
    angle and will be an impedance rather than a pure resistance.
    fred.
  3. David Harmon
    David Harmon Guest
    On 17 Jan 2006 09:05:45 -0800 in sci.electronics.basics, "thejim"
    Mainly, but if it says electrically short then I think it means
    having the electrical characteristics normally associated with an
    antenna physically shorter than the resonant length. Something
    other than physical length that affects resonance could be figured
    in.
    If the antenna is a resonant length for the frequency in question,
    then its inductance reactance and capacitance reactance cancel out
    leaving only the resistive components as seen by the transmitter.
    The current neither leads nor lags the voltage at the feed point.
    If shorter, it is capacitive + resistive, current leads voltage.
    If longer, inductive + resistive, current lags voltage.
    Or is that the other way around?
  4. John Larkin
    John Larkin Guest
    A short antenna looks like a capacitor.
    John
