Jeff Johnson
I have a need for a way to move a light around a geometry(such as on a
circle(not a disk)).
One way would be to have a single LED and "cover" above the led. The cover
has a small hole in it letting the LED light shine through. If hte cover can
be easily positioned then it would produce the effect I want. Because the
cover requires mechanical translation it is more difficult than what I'm
interested in (unless there is some trick to moving such things without
motors/pullys/etc... (I've seen some cool translation devices based on
piezo's somewhere).
In any case what I was thinking about was if there was a way to electrically
position light. Somehow using frequency resonance in 2D on an "led"
plane(I'm just making up stuff here).
Of course I could just use a bunch of LED's but this doesn't give me the
resolution I want, costs a ton, and requires a lot of circuitry.
Basically I just want to move a dot around a small circuit where the angular
position is controlled by an electrical single. Nothing fancy but just
something simple. I'm looking more about if it is theoretically possible
rather than some actual device since I doubt there is anything out there
that does this.
Any ideas how one can achieve this?
Just incase your confused on what I'm asking. You can also think of the
knighrider effect from the car. In my case I want to be able to be able to
have a continuous position(or close) and to be able to use a single signal.
piezo's somewhere).
that does this.
