Electrically actuated air valves
Discussion in 'Electronic Components' started by dg, Feb 4, 2004.
  1. dg
    dg Guest
    Can anybody recommend a source for electrically actuated air valves? The
    air source is currently 90psi but will likely be regulated to less, as the
    job does not require that much pressure.
    --Dan
  2. Tim
    Tim Guest
    Well I don't know if this will help much, but I got a dozen electric
    valves on e-bay. The seller didn't know what they manufactured for, but I
    found out they were pressure relief valves for fuel tanks. I got them to
    make a mechanical bottle rocket launcher, but I have gotten around to it
    yet.
    Good Luck!
    - Tim -
  3. Tried Grainger?
  4. Can anybody recommend a source for electrically actuated air valves? The
    Search for "solenoid valve". Surplus vendors such as mpja.com
    sometimes carry them, if you want small quantities. I buy mine from
    McMaster-Carr <http://www.mcmaster.com/>, which is an industrial
    supply house carrying everything you could want for building your
    pneumatic system. Prices are reasonable but not exactly "cheap".
  5. tweak
    tweak Guest
    I get mine from Graingers
  6. Jim Adney
    Jim Adney Guest
    Sure, the most common brand is ASCO, but you can probably find others
    by Googling on "solenoid valves".
