Jason said:
Ok the software part is a total breeze for me that is what I do. The
electrical engineering is what I need to get the data from the board to a
serial/ps2/usb/whatever port. The board has a 16 pin ribbon cable going
from the interface board to the main board which is where the processing is
done. My thought is to engineer a board that will intercept the ribbon
cable and get that data out to an RS232 port. Get my drift. I have done a
lot of reading on the arachnid dart machines and even contacted Arachnid and
they say that the machine was not designed for that and they won't help me.
Assuming you had enough specific info on the ribbon cable signals (which I
seriously doubt you'll ever find), you could design a fairly cheap interface
using a mid-range PIC Microcontroller and a few external components. The PIC
could be programmed to capture, buffer, and convert the ribbon cable's "data"
into whatever format you desire (RS232, USB, etc) for input to a PC. Even if you
manage to capture the desired data, reverse engineering that pure binary data
would be practically impossible unless you can obtain a helluva lot of specifics
about its format.
How long it would take to learn the ee stuff depends on how familiar you already
are with assembly language programming and microcontroller hardware interfacing.
There are a lot of tutorials and free ebooks and manuals (PDFs) on all of that
so you could pick up the necessary brainware.
Google search: pic microcontroller rs232
Download the complete midrange microcontroller manual at
http://ww1.microchip.com/downloads/en/DeviceDoc/33023a.pdf and learn it. Search
around the web for tuts and guides for PIC peripheral interfacing for data
acquisition and communications - there's no lack of info on this stuff. I'd
guess in about 6 to 12 weeks and somewhere around $400 - $800 for some necessary
hardware to play with the (programmer, breadboarding-prototyping kit, etc) you
could be getting the hang of it. The programming software is free (in assembly
language - C compilers cost $125 - $500).
Again, this all assumes that you can obtain a pretty good knowledge of the
ribbon cable pinout, voltage levels, signal timings, etc, of the data you want
to capture. You could get some of that electrical info by purchasing a rather
inexpensive ($500 after all is said and done) Bitscope 300 series - see
http://www.bitscope.com/product/ - to see the signals and timing relationships.
The software is free and can be downloaded and installed to see the interface
functionality. If ya need a couple Ebooks on programming and interfacing let me
know (only if you have a high speed connection). Ask questions at
http://forum.microchip.com/default.asp
Good luck,
Perion
