Electric motor control
Discussion in 'Sensors and Actuators' started by sartony.johera, May 5, 2012.
  1. sartony.johera
    sartony.johera
    May 5, 2012
    Ok so i need to hook up a small electric motor to a speed control so i cab adjust the speed obviously.. The motor will be running around 5v maybe less but i need to be able to measure the amount of electricity the motor is drawing. Any suggestions? The motor will need to turn an axle at a rate of 10-30rpm with or without gears but measuring of the power drawn from the motor is key.
    Thanx for any posts
  2. CocaCola
    CocaCola
    3,635
    4
    Apr 7, 2012
    What are the torque requirements?
    A converted to full rotation (360°) servo would likely fit the bill...
  3. sartony.johera
    sartony.johera
    May 5, 2012
    Its very minimal, im need to all this but if my calculations are correct then it should be less than 0.03 newton meters
