Electric fence
Discussion in 'Electronic Repair' started by Chuck Norisez, Sep 27, 2008.
  1. Does anyone have any data on electric fence controllers? I'm trying to fix
    one that uses a 6V battery for power.
  2. ian field
    ian field Guest
    There's plenty out there if you google, but they're mostly 12V.
    If you want to build from scratch you could try to find a supplier that
    still stocks 6V scooter ignition coils, or maybe a 12V car coil that's
    designed to work with a ballast resistor.
  3. Franc Zabkar
    Franc Zabkar Guest
  4. Guest
    Are you trying to fix one of the really old ones that use a 6 volt dry
    cell pack, or one like Harbor freight sells that is solar charge? The
    really old ones used a 6 volt turn signal flasher to close the
    circuit. Don't think they are legal in any state, now. I have one of
    the Harbor Freight units that has a bad solar charging circuit. Never
    had time to look at it. If this is what you have, would be very
    interested in what you find is wrong with them.
    Paul
