N
N_Cook
8 pin SMD with blown hole in the casing. Top mark , very indistinct maybe 2
lines
0h963
0h37
maybe very stylised 4 instead of h, logo very indistinct. My first guess is
a 555 but pinning not standard
p3 ground, p8 +12V, pin 1 to a 10uF cap , other end to 0V, p5 tied to p6
goes to speed change pot with also a line from the pot to p1. No obvious
output trace.
Removed the device and internal connections between p2 and 3 presumably
fried , and also p6 and 7
Other device is a 16 pin with ident scraped off or the conformal coating
dissolved off.
In passing , a 8x5x3 mm fuse with bo encapsulation , mainly 2 bare Al plates
with something between. Working order measures 0.18R +/-.01R, marked/punched
in the Al
100
B7L
never seen anything like it before
make/series/value?
lines
0h963
0h37
output trace.
dissolved off.
in the Al
100
B7L
make/series/value?
