Good ideas, but the door is very very heavy and I think your suggestions may
be a bit finicky.
Thanks.
| Ohhhhhhhh now it is making some sense. At first I thought you were
working
| on a handicap issue. It is much easier now.
| Simple solution #1 Pick up some coil springs at the local hardware store.
| Either drill holes to match diameter and epoxy or press fit into holes.
The
| holes would be in the jamb portion of the frame and would compress when
the
| door is shut and the mag is energized. When the mag is de-energized the
| springs would then just push the door open. You could install the spring
in
| the door itself at the top on the strike side. Mount and small angle
| bracket for it to push against. Simple?? Yes!!!!
| Not as Simple solution #2 Go to a local auto parts dealer and pick up a
| gas charged support rod. Like what is on lift gates or hoods. Here you
| will have to find one that has the right dimensions to fit your door.
When
| fitted properly and the door is closed with the mag energized all is well.
| When the mag is de-energized the gas piston will gently push the door
open.
| Please send all royalties to: Me
| Good luck,
| Les
| | > It's a hidden door to a safe room, the part that you would see if you
were
| > a
| > burglar is just a huge mirror...no handles no hinges.
| > | > |> Or..any other ideas?
| > | Why not just install a pull handle on the outside?
| > | Regards,
| > | Robert L Bass
| > | Bass Home Electronics
| > | 4883 Fallcrest Circle
| > | Sarasota · Florida · 34233
| > | 941-866-1100 Sales & Tech Support
http://www.bassburglaralarms.com
