H
Harry Bloomfield
I have a radio scanner in which the back lit EL panel has become very
dim. I understand that the EL panel can be slid out and removed from
behind the LCD display, for replacement, but replacements are no longer
available. I am only assuming it is the EL panel at fault, because it
is suggested to be a common fault.
Is there some method by which I could revitalise the brightness of the
existing panel?
Are these things made to standard sizes, perhaps one could be found
which is a near fit which might do?
Cheers...
Regards,
Harry (M1BYT)...
Remove the 'NOSPAM' in my email address to reply.
Free Amateur Radio Courses:-
http://www.ukradioamateur.org
existing panel?
Cheers...
Regards,
Harry (M1BYT)...
