Efficient video TX?
Discussion in 'Electronic Basics' started by Daniel Kelly \(AKA Jack\), May 20, 2004.
  1. Hi guys,
    From your vast collective knowledge, please could you recommend a video
    transmitter with the following characteristics:
    * very low power consumption (<70mA), ideally running at below 7.4volts
    * small size
    * transmits mono audio and colour video
    * transmits outside the spectrum used by WiFi (802.11b/g uses 2401-2483
    MHz). In practice I guess this means the video tx must use either 800Mhz,
    1400Mhz, 2300Mhz or 5800Mhz. It must be legal for use in the UK. What I'm
    after is a video TX that uses a "quiet" part of the spectrum. 2.4GHz
    certainly aint quiet (wifi, digital cordless phones, microwaves, AV
    transmission)!
    * available in the UK
    * costs less than 150 UK pounds
    * comes with a compatible RX which also has very low power consumption.
    Many thanks for your help,
    Jack
  2. I only need to transmit about 20meters.
    Jack
