That "current pulse" is AC, right? That means that for a fraction of a ns
it's a current pulse in one direction, and then for equally long it's a
current pulse in the other direction. The two average out to zero. And
they average out a lot faster than any component in a 741 can respond - the
diodes and transistors in that 741 aren't even fast enough to rectify the AC
so as to get a DC shift. (Put differently: take a look at the input
capacitance of the 741; now compare it to your desired sub-pF detector
capacitor.) Basically, the 741 is pretty much transparent to microwaves,
I'm thinking.
And by the way, you mentioned a "high strength microwave field i.e. from a
radar camera." Umm, I don't know the specifics but I'm thinking that if
they're aiming that thing at me, it's not very high energy. And if you want
to detect it from far enough away that you can actually respond with your
brake pedal before it's too late - that is, from at least a few hundred
yards - then it's very weak indeed.
Consider this: It is in the cop's interest for the radar signal to be as
weak as possible while still permitting detection - after all, they don't
want to blanket the area with radar signals that might give them away. The
radar camera has high-quality, purpose-built, sophisticated detectors. So,
the radar camera can put out a signal that is just barely strong enough for
its very good detectors to detect a bounce off your big metal object. Now,
you want to detect that signal from about the same distance (the cop has to
detect the bounce, so double the distance; but you want to detect far enough
in advance to slam on the brakes; so let's call it even). So it's a pretty
safe bet that your detector needs to be about as good as the cop's, to
compete.
