Easy question about Solar Cells / Electric Motor specs
Discussion in 'Electronic Basics' started by Mike V, Jul 4, 2004.
  1. Mike V
    Mike V Guest
    The short of what I'm doing is trying to power a very small electric motor
    with some small solar cells. I need to determine how many solar cells I'll
    need to power this motor (assuming perfect sunlight, anyway). Basically
    this comes down to understanding what the heck the ratings mean.
    For example, one solar cell claims to "produce 3.5 volts (open circuit) @
    6mA (short circuit) in noon sunlight."
    Does this mean that the maximum amperage it can achieve is 6mA? When it
    mentions open circuit versus short circuit, why is there a distinction?
    Does it only produce voltage when the circuit is "open"? I'm having a hard
    time making sense of that.
    Further, I'm looking at a tiny motor that has specs like:
    "1.5V gives 17.5mA free draw current (120mA stall) at 9700RPM".
    What does it mean it "gives 17.5mA"? Does that mean that the motor has
    sufficient resistance that, given any 1.5 volt power source, it will only
    let 17.5 milliamps through? What does the "120mA stall" part mean?
    I apologize for all the questions. I can easily find resources that talk
    about current/voltage/resistance, but I can't seem to find too many that
    talk about the specifics of these types of devices.
    Mike
  2. Tom Biasi
    Tom Biasi Guest
    Hi Mike, The cell will produce 3.5 V. with no load.
    Because of its limitations it can supply a max of 6mA.
    The motor will draw 17.5mA at operating speed (9700RPM).
    If the shaft is held to a stop it will draw 129mA.
    Hope this helps.
    Tom
  3. Gareth
    Gareth Guest
    It may help to think of the solar cell as a 3.5V voltage source in
    series with a resistor. This resistor represents the internal
    resistance of the cell. You know about Ohm's law since you mention
    resistance, so you probably know that the voltage across a resistor is
    given by:
    V = I*R
    where V = voltage in Volts, I = current in Amps and R = resistance in Ohms.
    If the solar cell is open circuit no current flows in the resistor so
    the voltage across it is zero and the voltage you measure at the output
    is the voltage of the voltage source (3.5V). If you short the output
    the current will be limited by the series resistance and the measured
    voltage at the output will be zero since all the voltage is dropped
    across the internal resistance of the cell.
    You can work out what the internal resistance is since you know the
    short circuit current and the open circuit voltage.
    R = V/I = 3.5V/6mA = 583 Ohms
    By thinking of the solar cell as a 3.5V voltage source in series with a
    583 Ohm resistor you should be able to work out what current and voltage
    you will get out of the cell for different load resistances.
    If the motor is stalled (not turning) then the current is limited by the
    resistance of the motor, in this case to 120mA with a 1.5 V supply. The
    internal resistance of the motor is therefore 1.5/0.12 = 12.5 Ohms.
    120mA is the maximum current that will be drawn by the motor (unless you
    turn it in the opposite direction to which it is trying to turn). The
    minimum current will be drawn when the motor is spinning freely at full
    speed, that is 17.5mA. The actual current drawn will be somewhere
    between the two depending on the load - more torque requires more current.
    Gareth.
